Ok so picked up an 04 xp di. Had low hours on it. Obviously was garage cause it looks new. So on trailer, it would start run, but when throttle it and it would die and wouldn't start back up for a while. So I reached in and shook the fuel filter really good. And then it seem to act normal.. start, throttle, it would return to idle and idle. Kill it, start it, kill, start. Was fine it seemed. Saw 6k on a rev. Seemed fine.
ok, checked the fuel pressure any ways and 27psi with lanyard on, start and it showed 100psi rev it and needle on guage start jumping from 80psi to 100+ psi. Never settles tho just jumps. not lower then 80psi, not over 115psi.
So I started few more times and starts with out a hiccup, (and this is with hose water connected fyi) sounds great, and revs fine. So I decide to toss it in the water.. starts up fine and take off and I'm doing like 3500rpms, feels like limp mode/or 1 cylinder. So rode it to my dock and made it doing 3700rpms probably on 1 cyclinder. Shut it off and try to start and starts runs for a sec and dies. Does this for like 15mins. Tell finally it started and ran same as it was, so put it on dock and here I am.
So I know there notorious for fuel pump issues. And I do have a parts ski with pump.. just wanna make sure I'm headed right direction? Anyone know of anything else I should be looking into first?
Also what suggestions on using used pump out of my other ski? or should I look into aftermarket pump?
Thanks guys
Thanks guys
