That's what i was wondering, thank you. It looks like the bellows and carbon seal have just been replaced as they look new to me at least, what signs should I look for on the carbon seal? I read somewhere that it will leak in through there is that correct? There are no signs of leakage in the engine compartment when I was running and out on the lake.The gap to the wear ring looks pretty big. Measure with a feeler gauge. Might be your problem. Also check the shaft bellows and carbon seal.
1. Do you just have to unhook the linkage for the steering and then the four bolts to pull the pump?
2. What oil does the pump take?
3. What do I need to reseal the pump on the boat when it is reinstalled?
Yea sorry about that auto correct got me lol. I probably should have deleted and reposted.I came here thinking this was an electrical/computer problem
Go to ****************** and download your ski service manual. It's no biggie to pull the pump and replace a wear ring. Pop the cone and replace the bearings if need be. All bits can be found online and won't break the bank. Good luckThank you for the responses guys, I appreciate it!! Lumps, yes you are correct the shot was looking in from the stator and still on the boat and I also thought it looked like there was a hole or that the end of it broke off possibly and the view from the front looked like the wear ring just started to fall apart but wasn't sure and wanted another set of eyes on it before I pull the pump. A couple other questions that I have now are ...
