RogerC
OK So i have finished putting my doo back together (2004 GTI LE RFI) after my flywheel epsiode, taken for a water test and found it runs pretty good. Only catch is it doesnt seem to want to rev above 5800 rpm and it seems to not want to advance beyond about 38 - 40 mph and i still have half throttle movement left on the trigger. It also seems to cough or surge (only slightly) every now and then. Low end seems to have plenty of response up until about 4800 rpm or 30mph so i believe the jet is ok (just had new wear ring instaled 5 hours ago). Also seems to want to idle at 1800 - 2000 rpm in the water which i thought was odd.
One possible factor could be owner prior to me had ran premix fuel and i just realised that i am running the VROI and premix.
My first thoughts were maybe RAVEs or plugs (new plugs 2 hours ago prior to my flywheel issue unsure about RAVEs but engine was rebuilt about 15 hours ago). Or could it possibly be just too much oil in the fuel system gumming up things at higher revs?
Any ideas or suggestions?
