Wont start
AngieD
My 1996 Seadoo Bombardier GTX wont start. Rode just fine last summer. It turns over really well but just doesnt want to start. Has brand new battery. I would like to know what you think I should do next. Thank you.
load test the battery,,,sometimes new ones fail…check for spark,,,and while you have the plugs out check the Compression,,,if these pass the test,,,throw some fuel in the plug holes,,,see if it wants to start momentarily,,,if yes,,,your issues are just fuel starvation,
What would be next if afyer you put fuel in the plug holes it still won't fire or try to ?
is the battery strong.?
Do you have spark?
Is the compression proper?
Yes battery is strong and new and on a maintainer. Tried another new battery from another ski. Same result. Compression is 150 on both holes. The spark is there but may be a little weak, is it supposed to be blue on the rfis? We ordered a coil ,has new plugs also
