wont start in water
iridea96xp
I was riding yesterday and to a brake for about 30mn and it wouldnt
start back pulled out of water and it started put back in and it died again
its a 96 xp thanks
Being hard to start could be a lot of different things. Bad gas, bad battery, loose or corroded wire connections, ect...I would do a compression test to see what is going on inside the engine. Here is some info on a compression test;
You'll need a compression tester. Go to Auto Zone. I think they sell for like $25.00. The compression gage, will screw in the cylinder head in place of the spark plugs. To test compression, remove both spark plugs. Place spark plug caps on the plug cap studs near the cylinder head to ground the empty caps. This completes the circuit of the ignition electrical system and prevents any electrical problems from the caps being un grounded. Using the correct adapter for the threaded end of the tester,( same length of the spark plug threads length)screw in the tester in one plug hole. Hold the throttle wide open. Push the start button. Watch the compression guage, when it peaks out at the most compression, let go the start button. Read the psi number. I would do it 3 times to be sure it is accurate. Check both cylinders the same way. The ideal compression is 150 psi per cylinder. If it is less, it's not a problem as long as they are close to being the same. If the psi is less than 90 it might need be time for a tear down and a rebuild. If the psi in 1 cylinder is say 140 psi and the other is 80 psi you need to tear down and repair. This difference is a lot then there is a problem. I hope this helps you.
Keep us posted on you progress.
Karl
water starting
i checked the compression both sides were between 148 150
any other ideas would be much appreciated thanks
kustomkarl you da man
Good, the compression is real good. Did you check these things; Bad gas, bad battery, loose or corroded wire connections at the battery and the ground wire to the engine by the starter?
Karl
May have a weak batery or conection, pick up coil or stator May be able to spin fast enough out of water to create a spark but in the water it may spin over alitle slower. This only guess so good luck. :cheers:
