Well 2nd launch of my 97 Challanger 787 and it started right up but as on the first trip if I leave the throttle in the center position it wants to take off. so learned to point it out from the dock, start it up leave throttle on lowest position it purrs like a kitten. run it at fast idle it has a sound like it is starving for gas....kinda like "brom brom brom brom brom" (nice sound effects) with it in gear no difference. Even with it running on dry dock, on hose for only couple minuts it makes the same type of sound in high idle in netural...sounds normal at low idle, it's smooth. I notice if I go from high idle to low idle it takes a couple seconds to smooth out, not real quick respons to throttle down. I think I will start with basics, Compression test, than pull carbs apart and check float levels and main jets for blockage. I already pulled the RAVE valves and clean all the carbon off the slide valves and checked for any cracks or dry rot on the bellows,looked fine.
Replaced the plugs with fresh ones,Br8es. Now about the rotory valve anyone ever had any experience with it causing a starving problem? On the first launch , new plugs ran like 45mph with 2 of us for about 4-5 minuts...than this problem.... the fuel isn't fresh( 2 months old)but it dosent have a foul odor and the oil injector is working, with seadoo oil, as far as I know. well if any one has any other Ideas I am open for a suggestion. It runs like crap but it looks peerty..lol make a great planter for the yard.
Thanks Karl
Thanks Karl
