Wiring problem with GTX IS 260 LTD 2015
russ22
Premium Member
Premium Member
I had to re-build my motor again as the intercooler was leaking water into the motor
I marked the wiring before I pulled the motor out but it rained and washed my marks of
Could you please have a look at the attached photos and tell me which Plug connection goes to the CPS, KS, OPS I know the 3-pin plug goes to the CAPS
The other 3 plugs are all 2 pin plugs, and they all fit each other.
I did have them connected but motor would not start while the motor was turning over the check engine light was on
should that be off while trying to start the motor
Thanks for your help
Russell
Use the colors on the wiring diagram to find the correct sensors. The TOPS sensor has to be snapped into the connector housing so that it is in a near level and flat position. If it isn't and you just let it dangle like you have it in your picture, it will think it's upside down and will never start, but will crank and crank, and will also throw the check engine light which shouldn't be on when starting.
