winterizing seized engine
lmntguy
anyone have any tips on winterizing a 97 challenger 787 w/ a seized engine I probably won't be able to pull it until after freezing temps and I need to preserve the core for exchange...
If you have an engine flush, get some sort of a pump, fill a bucket with antifreeze, adapt the pontoon the flush hose, turn the pump on. One concern is getting the coolant into the cylinders. You could punch the hose that goes to the exhaust and top the flow assuming it goes to the exhaust before the engine. If the other way around not sure how you'd stop it from happening.
Just follow my procedure for the 99 speedster. You pour the antifreeze in, no need for a pump that just complicated the entire process. It should take about a 1/2 gallon.
