Hey guys,
I thought I would share the results of an experiment that I did based on what the local dealer was telling me. I asked about winterization and they told me that BRP is now saying that running the engines to expel the water out of the intercooler and exhaust is enough now and adding anti-freeze is not necessary. I had seen nothing about this on the forum so I thought I would look into this myself a little closer. Here is what I did:
1: Ran each engine for a minute to warm up and then burst the throttle to purge water.
2: I attached an adapter to the rear flush port of the boat that allows me to pressurize the system with compressed air. It is the adapter I bought at camping world to blow out my RV's water lines. I did this on each side and could only hear a little water inside the lines.
3: I ran the engines again and burst the throttle once again.
Now to check how this did I removed the lines from the intercoolers to see if any water would come out. There were none and the lines were clear. So I took this one step further to see if there was any water in the intercooler. I removed each intercooler from the intake manifold and I got nothing but a couple drips of water out of them.
So based on this testing this seems like a great alternative to draining and filling the system with antifreeze. This is an 08 Islandia with the 430HP package. I did need to add antifreeze to the fresh water system as there is no way to pressurize the system to expel the water.
As always, your results may vary, but I am satisfied with the results of this experiment.
Steve :cheers:
Steve :cheers:
