I'm not ready to winterize the boat just yet, but I'm trying to formulate a plan, because I know it's coming.  I keep the boat at the lake on a lift under cover, and I'm trying to figure out a way to winterize it on the lift.  BTW our lake never freezes, or at least it hasn't in the last 25 years.
Here's what I have come up with so far:
1. Pull the boat out, on the trailer and service the lower unit, just change the lower unit oil, I put a new impeller in last year. Add marine stabil to the gas tank
2. Put the boat back in the lake and go for a short ride, fog the engine until it chokes out. Change the oil and filter, I have one of those suction thingies that pulls the oil out of the dipstick fitting.
3. This is the point I'm a little confused. Drain the water from the block, I think there are 3 or 4 drain plugs. Re-install the drain plugs and fill the block with RV antifreeze through the thermostat housing. Pump the water out and clean the bilge. Put the boat on the lift, put a couple of tubs of Damp Rid and cover the boat.
4. Remove the battery and take it home.
Notes on step 3, my old SeaRay all I ever did was drain the block, I did it that way for years and never had a problem. I guess the new theory is to either flush the block with antifreeze or in my case fill the block with antifreeze. Maybe I'm wrong but personally I don't feel that RV antifreeze has much if any corrosion protection. Mercruiser actually still recommends glycol antifreeze.
So does this sound like a plan? I'm certainly open to suggestions.
Lou
Lou
		 ..) but I start it in my driveway in the Spring with the hose attachment.
