*Winterizing 95 Speedster twin 657X's how to ??
I heard I do nothing but obvious fuel stabilizer.. and pull batteries....
anyone?????
do i do anything else to it?????
i have topped the oil and fuel, stabilizer in tank and ran through motor already on last run out...
other things??
thanks!!
There is tons of information on winterizing here on the forum. If you still have problems finding information, you could join as a "Premium Member" to get you own seadoo manual. There is a lot of things to do to winterize it.
Karl
Would anyone have more info ... than advising to join as a premium member??:(
looking for actual advice please... other than adding fuel stabilizer..
thanks!
You have to flush the coolant, fog the cylinders, change the plugs, change the jet pump oil, check your wear ring and Impellar. Lets of stuff. Just go to the search function and type in winterize! It will pull up a million posts on it.
