1. Run a short period of time just to get the water out of the jet
2. Use fogging oil and spray into flame arrestor until stalls
3. Open plugs and spray in there, turn engine over and then reinstall plugs
4. Clamp engine drain hose, t-hose from pump to motor and then gravity fill using the hose end from the jet
5. pour proper amounts of fuel stabializer
my question is this... rather than clamping all these hoses off, can I not just clamp the one hose that's normally clamped for flushing... and gravity fill using a funnel the coolant into the motor while its running to get it through to the heads, exhaust/waterbox, and jet?
Is gravity fill enough or do I need to buy a sump pump to get enough pressure through to get through everything?
