kunzman
My new 2012 only has one hour on it as I bought it end of season at a good price and no time to really ride it.
I need to winterize it and have found several different methods and am somewhat confused especially the fogging part.
Please tell me if the following would be correct:
I don't need to change the oil as it only has one hour on it.
I don't need to change the antifreeze as its still new.
I don't need to do anything special with getting water out of the intercooler as this engine is not supercharged, correct?
I will be using Sta-Bil to stabilize the fuel. I will do this first and drive it around on the trailer to ensure its mixed well in the tank. Next I will run the engine to get the stabilized fuel flowing through it. Should I do this running water through the flush port or will two minutes without be sufficient to get the stabilized fuel into the engine and not cause any harm. Dealer said you could run it out of the water for short period of time since it has its own cooling system. Is that correct?
Now comes the part I am confused on.
FOGGING PROCEDURE
a) Remove the two bolts that hold the fuel rail on. What size is the exterior torx socket?
b) Remove the rail along with the three fuel injectors.
c) Spray liberally XP-S Lube into the intake ports. How long is liberal? Can says 15 seconds per hole which seems long to me.
d) Crank engine several times while keeping the throttle fully depressed (drown engine mode) to distribute lubricant in cylinders, on intake and exhaust valves.
e) Carefully inspect “0” rings condition before re-installing fuel injectors. Replace with new ones if damaged. Lubricate the “0” rings with a dab of oil prior to installing (doesn’t matter which type, it’s just to ease the installation).
f) Re-install the injectors. Apply Loctite 243 and torque the two bolts down to 80 lfb.in, that hold the fuel rail on.
g) Make sure there are no leaks at the injectors while cranking the engine over in the next few steps.
Other directions also say to remove sparks and also spray XP-S Lube into there as well and crank at full throttle (drown mode). Is this redundant if you have already sprayed into injector ports? Again how long to spray?
Here is my other point of confusion. Since mine is a 130 and not supercharged I don't need to worry about this step below?
16. On the supercharged, intercooled models, the exhaust system is self draining but the intercooler and manifold need to the following protection.
a.) Remove both intercooler hoses.
b.) Let the intercooler drain, then connect the bottom hose.
c.) Pour about 6 and ½ ounces of antifreeze into the intercooler
through the other hose.
d.) Then, pour about 10 ounces of anti-freeze into the exhaust manifold.
CAUTION: If you fail to put anti-freeze into the exhaust, severe damage may occur to these components. You will want to use 100% anti-freeze in these components because it will dilute with water left over in the system.
17. And lastly, spray the entire engine with with XP-S lube (or WD-40) liberally, over all linkages and all metal parts. Partially lift the seat to allow any condensation that may build during storage. It’s best to use a cover to protect it from the sun’s rays while stored.
So I am to use the same fogging oil on all the exterior parts as well? Seems to be a waste of expensive fogging oil. Do most people just use WD-40 for the exterior parts?
Thanks,
FOGGING PROCEDURE
Thanks,
