benjilafouine
I downloaded the service manual for my Sea-Doo last night and watched some videos on YouTube on what to do for winterization. In a video by 3feetdeep, it is showing how to remove the IBR module and reach for the cone that contains grease and o-rings, change the o-rings and put some new grease. Does this part have to be done every year? My ski is only at 63 hours (only in fresh water, no salt).
I intended to change the oil even if I am far from 100 hours (oil a bit dark but clear) and of course winterize the exhaust but I wasn't expecting to grease the impeller.
Also, I saw on some videos that they remove water using an air compressor at 55 PSI but no one is putting RV antifreeze in there (even the service manual doesn't say to use RV antifreeze). Is the air compressor method only enough?
Finally, the service manual mentions fogging the cylinders.
Yours thoughts on this are appreciated.
