I just picked up a 2009 GTX 4-tec for the cost of the trailer it was sitting on. The POs bought it in 2021 and then it 'blew a ring' and was smoking the first day on the water. He started disconnecting things to pull the block but never came back to it. Gelcoat is chalked and the seats/bar pad are all sun damaged, but that's easy enough.
I had a nice conversation with the POs, after a bit of discussion I could tell that they really had no idea what they were talking about.
2 hour tow home went well, no trailer failures - which was a concern on a trailer that had been sitting for so long.
So I charged the battery and pulled the coils and plugs - And found oil on #1 spark plug (not the threads, on the anode)
So today I reconnected the battery and did a cold compression test. I also managed to get to the hour count on the ski: 186 hours.
So right now I'm thinking it's a few possible options: Oil was overfilled, valve stem seal failed, oil ejection via pcv...
I'm leaning towards just putting it back together enough to run it and see if I can recreate the problem. All he really did was disconnect the exhaust, intake and coolant expansion tank. (I'm pretty sure they drained the coolant as well)
| #3 | #2 | #1 |
| 170psi | 170psi | 140psi |
