Will not stay running. Help Please!!!
007Grizzly
Im new to the forum. Thanks for any help you guys can be. I have a 2000 GTX RFI. Purchased 2nd hand about 3 months back with 94 hours. Ski has been running good untill about 2 weeks ago. I took it out with my son and the battery was weak and would not start at the trailer. Did not have much time and not knowing any better hooked a battery jumper up to the battery and tried to start. After several tries the jumper finally gave it enough power to start, the jumper was weak also. Ran the ski for about an hour with no problems as usuall. Turned the ski off for a few hours to hang out at the water park. Weather starts to look bad so got to ski, started up fine, and headed back in. The ski starts to feel a little sluggish after just a few min. The more I rode the worse it got to the point it was just barely running, 4-6 mph. Thought the ski was going to quit any min. 1.5 hours later and one bad storm me and my son made it back (scary ride in rain, wind, and lightning). In a few days I check compression good and spark good. Put in a new set of plugs, take to lake, and run. Ski runs perfect for about 5-10 min and gets a new problem. Ski just quits. Try to start and after turning over for 15-20 sec. fires back up. Give it a little gas and runs rough dies again. Let set for a few, starts up, idles rough, but stays running give some gas for a few sec and quits again. Ski gets me back to trailer but continues with same problem. A few days later put another set of plugs in it to make sure its not them and a brand new battery and back to water. Same thing runs good for a few min then starts running bad and quits. I am thinking something is getting hot to cause this becaus it runs good till it warms up good. Before runing in lake after installing new battery and plugs I hooked up a volt meter to battery and started on hose for about 10 min and meter read 13 + volts. The rectifier does get really warm to the point you can just stand to keep your hand on it, not sure if this is usual. Sorry for such a long post but was wanting to give all the details. Thanks for any help.
