Bit of a wired on.
Everything was fine when out on the RXT300 I used the IBR for reverse to stop at a slow Speed. It then cut out and would not start as if the starter was Jaming. More a clunk noise.
The IBR bucket was stuck Up as well when we took it out the water and would not reset even over rideing it
I've removed the IBR module and the motor is fine as we tester it but it still will not turn over the battery is also showing 12.33 volts
Is there somthing else that can control the IBR. All the fuses are dine as well
