:agree: with Chester, sounds like a possible hydrolock! Pull the spark plugs ground the spark plug wires to the grounding post turn off your fuel or pinch off the fuel line, and with all the above done try starting the ski, you should see water shoot out of the head, repeat untill no more water comes out. I think you will have to do like a boil-out if water got in the lower end.
