will no run
bobs spx
Hello new at this I bought a 1994 spx that was stored for about 4 years. I put gas in it & hooked up water & started it up it smoked & ran rough for about 2 min. then cleared out & ran great for about 10 min. Then it stalled like it ran out of gas. It woud not restart i checked for spark it had none. I wiggled some wires & got a very dim spark & then check the modual it was bad I replaced it & the battery . Now I have spark . When i try to start it will fire & die right out. When the fuel filter is full it will run a second longer. It looks like the fuel filter will not stay full & takes a while to refill. I dont know if it a fuel problem or elctrical.Someone told me it could also be a problem with the armature or charging coil behind magneto.
bob...take the "return" line and go filter. Sounds like the fuel selector is clogged. By doing that, it bypasses the selector, and so, go from there.
