wierd. automatically turns when battery installed
chuey12
ok this is wierd...
the 96 xp was running fine. then the last ride i turned it off and this buzzing noise was noticed and wouldnt stop. i had to unhook the battery and then it stopped.
as soon as i rewired the batter the engine would turn; not turn on but just turn over. the key was not even plugged!!!
any suggestions??
its like bypassing the key altogether. the ski wouldnt start though...just constantly turn over when the battery is wired....
any info would be great!!
thanks..
yeah. like they said. the solenoid has welded the big washer to the 2 contacts. beat on it and it may free up, but it will just stick again. you may have already hurt your starter and/or flywheel running it with starter cranking constantly. good luck.
Easy....
It's a very easy task, just make sure you disconnect the ground wire on your battery before attempting to do this.
