you can replace the oil lines and injection oil lines from Ace...should replace the grey lines and for that matter, when was the carbs gone thru last?
Carbs gone thru last? ... uhhhh, Alex that would be, "What is 1995".
i think you need to replace your fuel lines ever year to be safe.
Only if you keep putting on the crappy gray ones. There has never been an issue if you have the black fuel lines from day one...say 1996. The rubber material in the gray ones is what breaks down.i think you need to replace your fuel lines ever year to be safe.
If I recall correctly there are a couple gray lines that are just vent lines that connect to the side of the ski under the insulation so you don't have to worry about replacing them (is that right Timmy?).
Just use regular hose clamps from the auto parts store, you need about 20, I just bought a small box of them. The old clamps are a little tricky without the clamp tool, but if you just grab em with a pair of pliers and twist or pry them apart with a screwdriver you can get them off in a few seconds.
Might be a silly question but why do you need so many clamps, doesn’t the fuel line just go from the fuel tank to the pump and then the carb. I have grey lines on a 2000 model and it runs great but am worried after all these comments but also wonder if it is the same with skis exported to Australia.
