Stevego
The same amount of weeds will get sucked in, grate or no grate. No gain with grate.
Rocks, same story - there is not enough suction to ingest a large rock, and small ones will get past the grate. No gain with grate.
Ropes, tree branches, same story - they all get past the grate. Its useless.
But without the grate, you may be able to clear weeds by backing in reverse, then pull the DESS key and coast in reverse, they will fall out the tunnel. Not so with grate on,
And, youll have to take it off sooner or later anyway, to clear a bad jam.
On the 150 Speedsters, it is held on with a lock nut inside the hull, almost impossible to remove due to intake hoses blocking it. Bad deal. Going to put the lock nut outside soon.
