turn the switch on and nothing happens... Any suggestions before I drop a check to the mechanic? The light on the switch comes on but not the blower...
Check fuse? If it's ok get your meter and make sure you have 12v at blower. If so, prolly need a new one--but check for loose wiring or corroded connection.
Dont pay a mechanic for something to simple. Get a 12 volt test light or meter. Check for power at the blower plug with the switch on. If you have power, try to find one online. If you dont have power, then check at the switch.
