I have a 98 seadoo speedster and one of the exhaust valves are leaking water out of the small hole on the bottom of the valve. Why is this happening and not on the other valve? I tool the valve part and it looks very clean inside.
More than likely the diaphram inside has a hole in it caused by the clamp rubbing against it.
Take it apart and examine the rubber diaphram
The other one is probably not far behind. I would examine both and replace as necessary.
Don’t loose the spring and don’t adjust the red cap as it is set from the factory.
That is what I was thinking. I notice the diaphragm assembly slides out very easy from the base including the washer. Can I superglue the washer in and then assemble the unit and this will keep the assembly from pulling out easily?
