k_dog345
Working on a 1996 Seadoo SPX.
I got two new genuine Mikuni needle and seats that I tried adding in my mag carb. Both have the same behavior of popping off at 60psi, there are bubbles coming from the the seat that leaks down pressure to about 40 psi then it will normally stop. This is on my mag carb. Pto carb does not have this issue. Anything I should be looking closely at? Symptoms on the water are hard startup and hesitation to accelerate until I get past the dead spots then it runs fine. Here’s a video
Could this part be the issue? I cleaned it as well as I could, but the metal tab that holds the mylar valve still had a little bit of rust damage. Wondering if this is the source of the bubbles...
