BuffaLoveBoat
Hi, so today I took my 150 Speedster 215hp out and my [water] temperature warning buzzer went off. And if I remember correctly it was flashing exhaust problem or something. I killed the power and checked the engine. The hose on the port side came off and water was gushing in. From what I understand it is water returning “cooler” from the plate and that hose going to the engine. My question is why wasn’t it the green coolant? From seeing it in my panic it was just clear water. I did jump back there next to the hot engine and reconnected the hose and pushed the clamp back on then trolled back to the dock. Fortunately it did not come loose again on my 1mph journey back. I was buzzing around full throttle when the alarm went off and I assume that’s when the hose came loose. Does the pressure increase at high speed?
Also the coolant level did not go down even though a lot of that water came in, why is that?
Another question is why did that hose come off at all? Naturally I’ll hope it was just a loose clamp but I did actually tighten it down earlier this week (this is the second time this happened). Perhaps I simply didn’t tighten it REALLY tight enough. I hope that’s it. But is it more then that like is this really high pressure and there could possibly be a clog? (Of course that’s possible, anything is possible) but do they clog often?
I know I have asked a lot of questions but just looking for some feedback, especially about why it wasn’t green.
Thank you so much for your time.
