I have a new to me 1998 Sportster 1800 with twin 717 engines. When I bought it one of the cylinders was full of injection oil. I pumped it out and got it running. On my first time out it was running great and I had it up to about 50mph. On the next loop around the lake a coolant line popped off and quickly filled the hull with water, submerging the engines pretty high up. I made it back to shore and drained the hull. I got both engines started, but now the starboard engine does not run clean. There is white smoke and a gray oily substance on the ground under that exhaust port. I have run it and checked the plugs and they are always wet, seems like oil and water combo. It will not clean out after running it quite awhile. I also used almost half a tank in injection oily in a very short period of time. There is no visible oil in the bottom of the hull. I am wondering if someone can tell me what is going on here, so I can proceed with the appropriate next steps.
