SquirrlyDan
I recently picked up a non running 94 XP with a 657X. The motor was toast, and the guy i bought it from gave me an extra engine that he was under the impression was a good engine, i went ahead and threw a new top end kit in the new engine before putting it in the ski. The original engine that was in the ski(blown up engine) had a 5 wire stator. The new engine had a 4 wire stator. I swapped the stator and flywheel(5 wire) out of my blown up engine, into the the new engine going into the ski. Skip forward and got the engine in and hooked up. The engine runs, but is hard to get it to come off of idle, bogs when you try to rev it and such, seems to kind of rpm search as well. From my understanding based off what ive read, that i had to swap the flywheel and stator because the timing is different on the flywheels from the 5 wire to 4 wire stator systems, but I did not change the rotary valve.
1. Is the rotary valve different from the 657x with a 4 wire stator to a 657X with 3 wire stator?
2. I know that the open and close degree spec is different from a 657 to a 657X, but is the spec different from a 657X with 4 wire stator, to a 657x with a 5 wire stator?
Thank you guys in advance for any help, im completely at a loss and the more post i read about it, the more confused i get.
