Which Garmin Transducer and Location for Garmin 53DV ChartPlotter / Sonar
JD_Pilot
Looking to install a Garmin 53 DV Chartplotter / Sonar in a 2001 Challenger 1800.
The Garmin 53 DV comes with a GT-22 Transducer.
Want to do a Shoot Thru Hull install.
Can I use the standard GT-22 Transducer or do I need a P72 ?
The GT-22 is a Transom Mount, has anyone glued one of these inside ?
Have read the threads here on mounting locations on other models,
can anyone refer me to a specific location for a 2001 Challenger 1800.
Thank You !
I just installed a Lowrance hook 4 outside the hull of a 2002 X20 basically the same hull design...I chose to install it outside of the hull so that I could retain the downscan and water temp functionality of the unit. It works great at all speeds - except reverse and tight turns as I get interference on the screen from the turbulence in the water. I have a thread on here with a video of my install.
