I have a 787 that has never been rebuild I had to remove the jugs to fix a water leak so I decided to replace the piston and rings while I had them off. I had a 150 psi on both cylinders and only one piston had some small scoring with none on the cylinder walls, total hours on engine is 200. I have been told that I should go with the larger pistons and bore .25. I don't really see a need if I still had 150 psi. I wasn't even going to replace the pistons but I noticed some scoring so I figure I might as well. When do you determine when to bore and when not to?
