Taking our boat out for a leisurely run around the bays, with flat water all day. It's a 951 with complete rebuilt carbs and all tempo lines replaced, non ethanol fuel used.
While running around the 3500 rpm mark, I can detect the occasional lowering of power or slight rpm drop. If I hit the throttle a bit, the engine quickly reacts to a higher rpm and holds. Anything below 3000 rpm, engine is stable also.
Are the RAVE valves activating somewhere in this 3000 to 4000 rpm range, and should I detect a change in engine performance when the valves move?
