Ya Im not sure how you miss that. Well I did but that laying on the ground and looking through the grate. As far as I was concerned I tugged on the shaft best I could and did not see anything unusual. So it appears no neoprene seal at the wear ring but there are 3 rubber grommets the go between the main housing and chasis then the 2 orings on the spout that goes to the rear housing. Did I read correctly that the grommets are unavailable? 3 total If Im correct. And Since there no ring to remove other than the lip seal could I install the new one with out taking the impeller out?
