HeresJonny
I recently acquired a 1997 Sea Doo Challenger 1800, and we tried to put it in the water this weekend. The engine is running well enough but we couldn't get it into reverse to get it off the trailer. We pulled it out and consulted the shop manual and these forums on how to check the reverse cable. I pulled out the shift and throttle levers and this is what I found:
Question 1: Is that cable really supposed to have the 90-degree bend in it? All the diagrams I've seen don't show a bend. It looks like it would line up much better if it was straight and maybe the bend caused the sleeve to crack. The bend also seems to shorten the cable which prevents the other end from pushing the scoop down all the way. Is it supposed to be this way or was it a repair gone horribly wrong?
Question 2: What can I do about this? I tried to bend the cable straight with 2 pairs of pliers and it wouldn't move. If I did manage to bend it straight, is it possible to get a replacement rubber boot (also cracked, removed in the picture) and metal sleeve? Or am I stuck replacing the whole reverse cable? With it disconnected the motion otherwise seems good.
Any thoughts on what I can do are appreciated!
