What Wal-Mart Battery can be used in 1997 GTX?
markrvp
I was at Wal-Mart last night looking to see if they had a battery that would fit in my 1997 GTX in the event I needed a battery in a hurry.
The battery I found that looks most similar to the one in my GTX now is the EVERSTART ES14LA2.
Can anyone confirm if this battery will work, or can you recommend another model?
Cold cranking amps....
I use the Wal Mart brand everstart in my boat. It has plenty of CCA to start my motor.
If your looking at this battery because of size, you need to look at what it's made for. If it's a lawnmower battery, then I"m sure it won't have what you need. If it's a motorcycle battery, with their compression ratio, I'm sure that would have enough CCA for what you need..........
