So... my engine took on water somehow, and it may have been my fault.
while on the water, it fired up and then eventually stalled and couldn't be started...
felt the plugs and found one cylinder not firing at all, and when I pulled the plug and tried to fire the engine, there was water spewing out, and even out of my carbs
I tried to pull the plugs and spin as much water out of the engine but to no avail...
worse part is, I accidentally dropped a bolt into the engine bottom end through on one of the ports while I was unbolting the carb... arg
I'm thinking the engine is eff'd now... so its likely I need to get a new core
whats the recommendations guys? go to SBT?
