Hi Everyone, chasing the infamous "surging" and "dying" after after 30 minutes issue (2000 Challenger Model 2000 240 EFI), will be changing all of the fuel lines and today I removed the VST unit and sure enough there was quite a bit of gunk in the bottom section under the filter . Thought while I have it apart I would replace the pump just as a pre cautionary thing since its a bit of a chore getting it apart and its the original unit .. I say original because the hose clamps used on 2 of the hoses were the 1 time use ones that Mercury used when built .. you know .. the ones which are a real pain to remove Lol.
As we know the Mercury original part number of 809088T1 is not only through the roof for cost but is probably not available. I saw these from Quantum which appear to be ok from the pictures .. what do you folks suggest when it comes to replacing these high pressure pumps.
Thanks in Advance
MERCURY 150 175 200 225 250 HP Marine/Outboard 96-01 Fuel Pump + Gasket 809088T1 | eBay
Thanks in Advance
