I had it out at the lake for the first time yesterday, it's a 96 Challenger with the 787, and I had a couple issues with it. It was experiencing some sort of cavitation or power loss at low speed, like I would throttle and it would rev up but not take off that fast. Once it got going it was pretty good and I was still able to hit 45 mph (indicated on speedo that is). From some reading I have done, this sounds like it may be a drive shaft seal? Or should I be looking at the impeller/wear ring? I thought that was less likely as it still worked well once up to speed. My other issue is with the throttle, I can't go full throttle on the lever or it starts to bog out and the revs drop. It will hit 7000 rpm but it won't go any more than that. Aren't these supposed to hit 7200 rpm? I am really not sure what is wrong there. I am thinking I will clean out the rave valves just since it probably needs to be done, but the posts I was reading usually describe other problems to do with the rave valves so I don't think that's the issue but I could be wrong. That is why I came here to ask the experts.
