What Impeller?
Twostroke
Looking for a new Or used good impeller for my 2004 155 4 tec what would be a good pitch over stock? I pull tubes quite a bit.
2000 G16
Jakes lift
Custom Paint
I would stick with factory pitch. Seadoo does a good job matching engine output to pitch. You're not making enough power to twist a different pitch fast enough so your performance will suffer on either end depending on pitch.
Unless you do something to add increased engine performace, stay with stock.. In most cases, you gain on one end but lose on the other. So if you get better out of the hole performance, you lose on the top end for example. That said, Skat has impellers of the same pitch and what not but are a different design. You will gain on the bottom end and normally a bit on the top as well.
