What impeller do i get??? Seadoo gti
soloblazer
Hey guys i need a impeller for a 99 seadoo gti 720, it has a solas pump on it, not sure if i have to have a solars impeller or if i can use any impeller for it, the pump number is sd nz-85. any help would be great.
impeller
so does that mean i can use any impeller that will fit on a 99 seadoo gti 720 and it will work with this aftermarket solas pump. correct??
I would guess from his reply that you can use any impellor of the right size. As for the pitch that depends on your engine size, mods, what you indend to use it for, ect.. I used a skat trak swirl and it works excellent. Never had to pick a weed out of there all year. I do have an aftermarket grate as well which might help.
