Hey guys,
Ok so im doing the top end of a few of my ski's ( 95 xp and gtx ) and I had what looks to be the same damage on both ski's from the same side cylinder ( front of the ski one, the mag side right? ) The skis are from different owners from different states, so different riding conditions. So why did this happen? I took the piston the the shop that is boring out my cylinders and they said it might be from a few different things. I said maybe got to hot and had lack of fuel or oil. They said maybe but if that was the case, most of the time the top of the piston will be burnt or something and he didnt see that. So what do you guys think happened? I want to fix the problem so it dont have to do the top end again if its a bad oil pump or clogged carbs or what not. I pulled the carbs and they look clean so far. Havent been able to get the fuel side of the carb off just yet ( was on was to tight ) but will be re building and cleaning them, but they look super clean so far.......:facepalm:
