Have A 2003 Sportster I Know I Need A New Wear Ring
But What Caused It To Fail? Could Not Go Fast
And Felt A Vibration In High Rpms . I Sucked Up A Fishing
Wieght , I Dont Know If That Was The Problem Or If Something
Is Wrong With The Impeller
Check to make sure intake grate is not cloged and look to see if impeller is damaged, or if you have a damaged drive shaft and or coupling. This is for vibration. Good luck Robin :cheers:
