I have a 2005 GTX with 38 hours and was having troubling starting it. I'd get the beeps when attaching the lanyard, but when I pressed the start button, I'd only get a slight buzzing sound. I would then pull off the lanyard, reattach and try again. Sometime it would start, sometimes it would take 3-4 times.
After checking the battery and connections, I brought it into the dealer and here are the notes from the work order: tested continuity of solenoid switch - every few times it would be open circuit or high resistance - tried new switch - problem still happening - removed PTO cover and found bad teeth on the flywheel and starter drive - replaced both. So for $800 I got a new starter and starter gear.
I'm wondering if I did something to cause this as I suspect a starter should last more than 38 hours. I'd really like to prevent replacing again...
