HI!
Got a used 93 SP 600 with yellow rotax engine, someone before me changed the carb and intake and it doesn't run right. It's a 44mm measuring the carb's outlet diameter.
What size carb did this engine come with originally?
I'm also thinking it may be a weak coil or condensor, since it will run barely ok (surges and is hard to build-up to speed) for about 10 minutes, then do nothing but idle. Plugs are burning a nice chocolate brown.
What do you think?
Thanks, Steve W.
What do you think?
Thanks, Steve W.
