Mitchapalooza
Hi Folks,
I've been lurking on the forums for a while now and I have to say the posts/advice that I've looked at so far has proven extremely helpful in getting me this far - so thank you all very much! Also, thank you in advance for any responses to this thread. Your advice and opinions are valued heavily.
I have a 1992 SeaDoo GTX Bombardier (white 587 Rotax) that my dad purchased back around 2000. We used it for a couple of years until there was some kind of issue (too long ago to remember exactly) and we put it in storage. Completely forgot about it until a month ago when we were cleaning out our storage buildings and I decided to see if I can get her running. I was successful in getting it started several times and opted to take it out to the lake yesterday to get some time in. However, when I got it in the water, it would not ignite. So far, I have done the following, though I'm new to working on these engines and am not sure what the next step is to get it running well/reliably.
First, I pulled the carbs (dual Mikuni) and did a full rebuild on both. They actually didn't look terrible, though I rebuilt them anyway. I used an aftermarket kit from Amazon (I know, should've used OEM Mikuni but didn't want to sink a ton of money into this project) that had multiple 5 star reviews. I reused the original springs and set the pop-off pressure at 26psi on both - tested multiple times.
Tested the oil pump while I had it off and it drew oil just fine. Replaced the two 3/32 Tygon oil lines on the pump.
Replaced multiple fuel lines. The original gray lines had already been replaced with black automotive lines prior to purchasing it, though I replaced any that had any kind of cracking around the ends. The rest look good.
Flushed the fuel tank.
Put brand new battery in it and cleaned the terminals.
There was some oil in the hull and some remained in the lines when I found it. I pumped the oil out and refilled with Walmart Quicksilver Full Synthetic. It is holding oil and I have not lost any thus far except for very little when I primed the oil lines.
Replaced the in-line oil filter.
Put a couple of gallons of premix in only to discover there was no spark. I pulled the electrical box out and took a look only to find that the 15a fuse was destroyed. Tested for power at ignition coil and there was none. Separated the black/red connector from MPEM and got spark and ohm tested entire electrical system, so I found it was a faulty MPEM. Ordered a new one (updated model with fuses built in rather than relays) and instantly fixed spark issue.
Tested start/stop switches and they all check out.
Wasn't getting fuel and found there was pressure relief when I unscrewed the fill cap so I went through the fuel system and found that the pressure check valve on the side of the hull was clogged with dirt. Blew it out and now carbs are receiving fuel - I can see it flowing through pulse valve and between the carbs.
Removed and inspected petcock. Tested it by blowing into the fuel lines in various positions and it appears to be functional. Removed fuel/water separator and o-ring was good. After it started getting fuel, the filter cup filled up, which is good.
Replaced both spark plugs (correct model and gapped at .024) - have good white/blue spark. They both look clean and slightly wet after getting it running.
After all this, I got it started though it was revving away. I put it on the hose and ran it for 15 minutes via the procedure in the manual and it ran okay. It revved away slightly a couple of times, though I pulled the choke slightly and it went back down to around 2000-2500rpm.
Pulled it home and ran it on the hose again for a while. It idled consistently around 1500-2k RPM and after a few minutes it died. I was not able to get it started for a while after this, so I pulled the air intake/flame arrestor just to troubleshoot. Pulled the plugs and cranked on it a bit just in case there was any water in the engine since it died on the hose. It is getting fuel (have used premix to be safe) and good spark. Ran the battery down a bit attempting to get it started so I left it on the charger overnight.
Came out the next day and attempted to start it again. I likely flooded it so I cranked it with the petcock off a couple of times and managed to get it started.
Ran it on the hose again for a while and didn't have any issues.
I brought it out to the lake and after I dropped it, it would not start at all as mentioned above.
These are the issues that I have noticed and could definitely use your knowledge/advice on.
Tested the compression (both with one plug in and both plugs on the grounding posts) and came up with a consistent 118 on the mag side and 120 on the PTO side. I know that this probably means it is time for a top-end job, though it should still at least run at this compression to my knowledge.
When trying to start, there is some visible fuel sputtering out of the mag-side/fuel pump carb. I'm not sure if this is normal or not. As mentioned, I can see fuel coming in from the pulse line and between the two carbs.
So, I have spark, acceptable compression and fuel. I have not opened the magneto cover, left the RV alone when I pulled the carbs/oil pump and the PTO spins a what looks like a normal speed when cranking the engine.
I'm at a loss as to what to do next. Any help would be very much appreciated. Sorry for the long story, I'm trying to be thorough.
Thanks!
Thanks!
