parkericharda
I've been having some issues with my Strbd engine on my 1996 Sea Doo Speedster. I've had the issue for years, but only recently has it become a big enough issue to need to diagnose and fix. This boat is old enough now, the dealers won't work on it, and the marinas are generally much more expensive (if they can figure out the issue). Here is what I am experiencing.
1. Sometimes when I go to start it, it will not crank but 1 time, and then when I push the start button again, it gives 1 long beep. I have to then remove the lanyard key and wait 5 seconds, put it back in, and then it starts ok, although it seems to struggle to start cranking, but once it has started, then it's fine and will start.
2. I'll be out running 5-6k rpm or so, and all of a sudden it will drop down and can't get higher than 3k or so. If you give too much more, it then seems like it cavitates or there's just no additional power there... it's strange. Wear rings and impellers look brand new! When I'm running it at home with a hose, it idles at 3k rpm whereas Port engine idles
k. So I don't know if it is a rev limiter issue (I don't know where this is even) or if this ignition coil has anything to do with it.
I'm fairly confident this has nothing to do with gas, because this has happened for years, and I run through gas frequently. It doesn't happen ALL the time. The impeller area is also clear.
I switched ignition coils, and the engine seemed to idle lower (like the port one), but not sure that solved the problem completely as I was at home and hard to tell with hose hooked up. Where is the rev limiter and does it have anything to do with the ignition coil, or does that just send spark to the plugs?
Thanks!
k. So I don't know if it is a rev limiter issue (I don't know where this is even) or if this ignition coil has anything to do with it.I'm fairly confident this has nothing to do with gas, because this has happened for years, and I run through gas frequently. It doesn't happen ALL the time. The impeller area is also clear.
Thanks!
