I'm gonna start testing but this is hella strange. Speedo Operates to about 20mph. When I go over 20mph accelerating the speedo reading drops to 15 and may meander up to 20 or 25mph. If I accelerate to about 5500rpm the speedo may hold 20mph. As soon as I back off the throttle the speedo jumps up to the correct speed. When I add power the speedo drops down below 20 again. I did this about 5 or 6 times to prove it out. Both the INFO speed and analog speed readings are the same. This will be interesting. I am thinking it is an electrical issue as supply voltage at higher engine RPM is being affected. Might be the rectifier. I'll check the connections of course but the erratic behavior doesn't make me think the root cause is the speed sensor. As I said, this will be interesting.
This is my personal GTX that has a new engine I am breaking in. I'm finally getting to the point durning break-in were I can cut up some. I've very gentle during engine break-in. I gotta say, I think the 1996 GTX and all those with that hull design are GREAT SKIs.
