lrschaefer
I think the wear ring on my 97 Challenger needs replacing - figured I'd put the symptoms in front of the experts before chasing after it...
The boat powers up nicely up to about 4500 rpm, but doesn't quite plane off. If I push the throttle further, it's like halfway stepping on the clutch - the engine revs up but the pump loses power. If I back off, it re-engages. If I play like this with it for a while, I can eventually get it to creep up to 5000 rpm without slipping, and finally plane off. Once I plane off, it seems to run fine, staying fully engaged right up to full throttle.
I'll double check the intake with a flashlight as I've seen mentioned elsewhere in the forum. But failing that, are these the symptoms of a bad wear ring?
