You have the thrust bearing pinched. You need to pull the cone and make sure you didn't damage it.
Easiest way to prevent this is to put the pump shaft in a vise with the impeller threads up. Then install the thrust washer, thrust bearing, pump housing and then thread on the impeller, this way the bearing can't fall into the groove and get pinched.
