hookdonspeed
helped a friend rebuild his carbs the other day, the one carb's fuel inlet was 100% blocked (non fuelpump carb), he took it to a local PWC shop and they "fixed" it for him, got it all back together, starts and ran find on land, started and ran fine in the water for about 10minutes, then cut off again and wont start back up...
is there a way to test to see if the fuel lines are blocked without having to pull the carbs off and disassemble again?
its a 2001 sportster with a 951, non DI obviously.
