Had the boat out twice this weekend, 1998 challenger 1800, twin 787's. Ran fine all day Saturday. Right engine was a little difficult to start Sunday after it was warmed up. After that everything seemed fine. I stopped to pick up a water skier, started up and got steady beeping, hit the fuel button on the dash and that stopped the beeps. Thought it meant low fuel. It was at a 1/4 tank. Went to head to shore and the right engine began to surge from 5000 to 7000 rpm up and down. Got fuel, checked plugs (mag side was wet, pto side light brown and dry). Started up and it ran fine for 5 minutes then the surging began again. Shut it down and limped to shore. Now it is extremely difficult to start, and won't rev past 5000 rpm with occasional surges to 7000. It dies at idle and has a continues "backfire" out of the carb into the air box. Got it started again and had my father drive while I checked the engine compartment. The right side water regulator was leaking, as the screw had fallen out of the ring that holds the bellows. Did I overheat because of the failure? There was water coming out of the telltale all day, but I suppose that could have been from the good side. I'm on my way to town to buy a compression tester. Plugs are new, water regulator put back together, all fuel lines tight. Anyone have any thoughts? I'll post the compression once I get back to the lake. Can I even test compression in the water?
Thanks, Dan.
Thanks, Dan.
